    Feb 2006
    India
    HEllo there
    i was wondering what r the BESTsoftwares for the following purposes:
    1.Create VCD from any format (with fast speed and good quality)
    2.DVd 2 VCD conversion
    3.fit dvd9 to dvd5
    I know i could have performed a search before i post
    but i dont want to spend time to try every software when u can just tell me the softwares which r tried by urselves and r best out ther
    For any format to DVD i have tried winavi and its a best application i suppose
    Looking ahead for replies
    Thx
    USA
    TMPGEnc encoder
    DVD2SVCD
    DVDShrink
    Anything but WinAVI. Try the freeware version of DivxToDVD.
    Feb 2006
    India
    is ther any way to copy DVD files which have crc errorss:
    plz help fast
  4. Mod Neophyte redwudz's Avatar
    USA
    DVDFab Decrypter, then DVDShrink usually works to backup your DVDs.
    Feb 2006
    India
    dvd decrptor cant read my DVD file (single movie out of 4 in dvd)
    but my dvd player can play that video
    Feb 2006
    India
    well
    what is BEST VCDburining software
    nero takes ages to encode video files
    Thx
  7. Member pchan's Avatar
    Mar 2003
    Singapore
    Never use Nero to encode. For VCD, use TMPGEnc to encode to VCD format(MPEG1). Use Nero to burn the MPEG1 file to CD using Video CD option.
    You can get a free VCD encoder at http://tmpgenc.net
  8. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    what r the BEST
    https://forum.videohelp.com/viewtopic.php?p=1388992#1388992
    I like TMPGEnc, and its free version is unhindered. TMPGEnc Plus unregistered can also do it (you lose MPEG-2 encoding capabilities after 30 days IIRC).
    EazyVCD. Actually uses vstrip, DVD2AVI, besweet and Tmpgenc (and optionally ChapterXtractor) and can create MPEG files ready to author or bin/cues ready to burn. Personally I don't see the point in learning the manual way when this software makes it all a breeze.
    3.fit dvd9 to dvd5
    DVDShrink. DVDRebuilder is also well-supported around here. Don't forget to acquire a ripper such as DVDFab Decrypter, DVDDecrypter or smartripper also.
    There are so many formats and so many user preferences that the one that works best for YOU is the software you should be using. Unfortunately you'll need to do a bit of experimentation, but I guess we can always cut the list down for you. Don't forget that while you're waiting for responses to questions here, that's time you could be "doing" instead of waiting
    Take a look around here for how many posts that have problems with WinAVI. And don't forget that people associated with the company spam here every week.
    I would second convertxtodvd for the quick n dirty jobs, but in all honesty, you just can't beat the flexibility of using dedicated encoders to really cover all situations.
    well
    Exactly. Nero is re-encoding. Which possibly means that your video wasn't VCD-compliant either. You can turn it off though - " untick the Create standard compliant files" (or similar) and it will just burn.
    VCDEasy is well-regarded around here too.
    If in doubt, Google it.
