I have .vob files that I want to edit at the begining and at the end (about 1 to seconds worth). I have tried this using programs that MAKE you convert to I believe MP2 (I may be wrong here) then you can easily cut out what is not needed. My problem is that when it is converted back i have sync problems.
Does anyone know a program where I can edit without converting? (edit while the file remains a .vob file)
Thanks so much for the help,
George
Some DVD authoring programs allow you to bring in vob's so you can edit the in and out points, also change the chapter points.
TmpgDVD author, Ulead DVD apps and others will do this easily. -
Will these apps have to recode the new .vob file? My files are about 4 minutes long. i just want to cut out the 1 to 2 seconds off of the firont and back. Will this take another 4 minutes per file to recode?
VideoReDo Plus performs frame-accurate editing directly on vob's, and only re-encodes at the cut points. It also corrects any sync problems in your video.
http://www.videoredo.com/Products.htm
There's a 30-day free trial. -
Check the guide's section and you will find my guide on commercial removal for free .
It's acurate ... but if you have any audio issue's at the start , you must fix them first .
Though this might not be an issue , it is worth considering .
Problems editing .VOB files
By Jose_A_Duran in forum Newbie / General discussionsReplies: 7Last Post: 14th Feb 2011, 15:44 -
Editing one of the .VOB files
By Yaro in forum EditingReplies: 94Last Post: 4th Sep 2009, 15:52 -
Editing VOB files
By lika in forum Newbie / General discussionsReplies: 16Last Post: 24th Apr 2009, 13:51 -
Editing .mov files and .ifo/.vob files
By redhot in forum EditingReplies: 7Last Post: 25th Nov 2008, 07:31 -
editing vob files
By newtie in forum Authoring (DVD)Replies: 7Last Post: 5th May 2007, 09:19
