I used adware to scan a computer that had a bunch of advertising, Parasites and cleaned up most of it, I also ran a scan disk, windows update. Even the desktop had a virus screensaver. I located the screen saver and deleted it, and now when I right click on the desktop/properties it doesn't display anything, like if I erased the main page.Just the icons appear with a white page.
Now If I reboot the pc I can access the internet but after a few minutes I cannot open any icons or go into start programs and open anything.
I cannot even go to control panel. And if I close the internet I cannot get back in, unless I reboot the pc.
This pc has windows pro and it's a custom built pc.
Should I just reload windows xp?
If my drivers do not load back, is there a good website where I can scan the computer and load the drivers?
Thanks for your help.
I'd reinstall windows. Freshly.
You can go 1 of a couple of ways with drivers:
1. Let XP autodetect and use its own drivers. Should get most components going to a workable state. Surf the web for the correct drivers and use if required.
2. Download all the drivers now, prior to reformatting. I normally use google and just search for a model number (normally found on the chip part of most components). Or you can search places like driverguide.com.If in doubt, Google it.
Blackmagic Design Control Panel
By Norwalk2006 in forum Capturing and VCRReplies: 1Last Post: 14th Sep 2011, 17:32 -
Control Panel --> User Accounts, NOT SHOWING/WORKING. Help!
By UmmAddan in forum ComputerReplies: 6Last Post: 21st Aug 2010, 08:33 -
Looking for a 3.5" Front Panel to Control VMC
By eist1 in forum Media Center PC / MediaCentersReplies: 0Last Post: 7th Nov 2008, 13:45 -
The avatar control panel here smells a little like cow dung
By Eat Right in forum FeedbackReplies: 1Last Post: 8th Jun 2008, 15:53 -
Vista - Control panel failed to open with Realtek ac97 unistalled?
By amdk62 in forum Newbie / General discussionsReplies: 3Last Post: 9th Oct 2007, 14:15
