can someone tell me if it is posible to convert a powerpoint presentation to a dvd so as to be veiwed on a dvd.
i have a powerpoint presentation of a friend and would like to play ot at his birthday party but there will be no pc available only a dvd player
even if it can be veiwed as a vcd would be fine
come on brains help me out
There are a couple of applications that claim to do this, however by all accounts they are limited in how well they do it. Google will find most of them.
If there is animation and other effects you are less likely to get a good outcome from these programs. If they are stills, you are better off taking screenshots and creating a DVD from these.
Your other option is to use a screencam program like FRAPS or similar to record the presentation while it plays back.Read my blog here.
I think there's some payware called powerpoint2DVD (funnily enough). However the program's authors seem to like spamming our user guides forum here with "guides" for their products, so I'm loathe to recommend them.
As guns1inger said, google or alternatively setting up the powerpoint presentation to run synchonously and then screen-capping it might be a more viable option.If in doubt, Google it.
How to add a DVD video to a Powerpoint Presentation
By andy jackson in forum Newbie / General discussionsReplies: 3Last Post: 17th Feb 2012, 13:27 -
how can i convert a powerpoint presentation and put it on dvd
By shashgo in forum Newbie / General discussionsReplies: 7Last Post: 8th Oct 2009, 04:14 -
Question about cutting clips for a Powerpoint presentation
By tanealbhandari in forum Newbie / General discussionsReplies: 16Last Post: 10th Dec 2008, 11:38 -
Powerpoint Presentation to Video/DVD Software
By Nasho23 in forum Newbie / General discussionsReplies: 2Last Post: 11th Apr 2008, 00:59 -
Which video format works best in a PowerPoint Presentation?
By foochuck in forum Video ConversionReplies: 1Last Post: 4th Oct 2007, 10:54
