Hi, I'm fairly new here and I've STF but found nothing pretaining to my question. I have a fairly extensive DVD collection and I use DVDTheque to catalog them. It has the option of linking a Movie Trailer to each entry. Problem is with many of the older DVD's it's nearly impossible to find a Trailer for the movie to download but nearly every DVD has the Trailer on it. I would like to extract the Trailer and save it as an .mpg or .mov on my HD so I can link to it for previewing my DVD's. I have MTR, YadeX, Toast and Popcorn but can't figure out how do this. I'm running a G4 533 Dual with OSX 10.3.9. Any help would be appreciated.
Play the trailers from the DVD, note down the title(s) and chapter(s) from the display. In MTR, select the title with just the trailer, like my example shown below. Use MPEG Streamclip or ffmpegX to turn the VOB into a QuickTime playable file.
Cool! I'm going to try that tonight and see how it goes. Thanks!
Personally, I wouldn't want to be without the invaluable freeware application MPEG Streamclip. To get the most out of it, you need the Apple MPEG Playback Component for QuickTime (OS X version), available as a $20 download from the Apple store.
With the Apple MPEG component installed, Yade X gives you decent previews of exactly what you're ripping. So on a DVD that's crowded with extras (like a handsome simulfax copy of the director's baby shoes), you can use Yade X to preview frames from the DVD, visually locate the trailer, and rip it as a VOB.
Then open the VOB in MPEG Streamclip, do a Cmd-F to fix any timecode breaks, and from the file menu choose Convert To MPEG with MP2 Sound. This will create a file that QuickTime Player can play natively, without the need to download any special codecs.
-Pianoman
How to author & burn a DVD from VOB trailers/files
By Baldrick in forum User guidesReplies: 62Last Post: 30th Sep 2011, 05:39 -
Add new subtitle to an existing DVD with warning screens, intros & trailers
By Charmer in forum Authoring (DVD)Replies: 7Last Post: 11th Aug 2011, 17:59 -
Removing Trailers from a 4.9GB DVD to fit in a 4.7 GB DVD+R
By rotchild in forum Newbie / General discussionsReplies: 5Last Post: 16th Jan 2009, 18:20 -
Setting up short repetitive WOW trailers on dvd (in HD)
By malisamson in forum Newbie / General discussionsReplies: 3Last Post: 22nd Aug 2008, 04:36 -
How to extract subtitle stream in .divx file and save as idx/sub
By newnews in forum SubtitleReplies: 1Last Post: 29th Jul 2008, 13:36
