Ok I'm using Adobe Premier Pro to mix 5.1 surround sound for an independant film. When I'm mixing the sound in either the audio mixer or timeline, all I hear is stereo. The sound effects do not go from front to back or vice versa. However, when I export the file as an .avi with 5.1 channels, it works perfectly, sounding exactly as I mixed it. I know I have an ASIO-compliant sound card as it's a Sound Blaster Audigy. What else can I try here?
Results 1 to 1 of 1
White Fields in Premiere Pro exported video, problem doesn't exist in VLC
By austin8159 in forum Video ConversionReplies: 1Last Post: 10th Aug 2011, 20:50 -
strange sounds in audio exported from premiere pro cs3
By codemaster in forum EditingReplies: 0Last Post: 25th Jan 2011, 19:57 -
Export Multi Audio using Premier Pro CS5. How ?!
By SB4 in forum EditingReplies: 16Last Post: 21st Nov 2010, 04:08 -
Import Premier Pro 1.5 Project into Final Cut Pro/Studio 3 - how please?
By rjamesd05 in forum MacReplies: 1Last Post: 6th Sep 2010, 14:50 -
Exported 1080i Premiere Pro CS4 sequence - out of sync
By nitrous in forum Software PlayingReplies: 9Last Post: 18th Oct 2009, 13:16
