Hi there..
Just bought this:
http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4139_141435554,00.html
And when it burns a DVD it burns the files into .vro files.
I want to convert these dvd-r's to dvd+r's that will work on most stand alone DVD players. Please tell me I am not out of luck.. :/
Marty
Tips here: https://forum.videohelp.com/viewtopic.php?t=264469
You can simply use TDA and re-author to a new DVD. Copy the VRO to your hard drive first. TDA has a basic edit function as well if you need it."Art is making something out of nothing and selling it." - Frank Zappa -
Excellent.. I ended up using Ulead DVD Moviefactory and made some pretty nice discs. But now I have an odd problem.. when I go to transfer the Vro file to the hard drive, my computer completely freezes once the transfer is finished.. it wasnt doing this before so I dont know what changed to do it now but it happens every time. Any ideas?Originally Posted by ZippyP.
I am trying to do a VRO to VOB conversion:
I copied the .VRO file over to my hard drive and launched TMPG DVD Author. I created a new project, selected "Add DVD Video", and selected the VRO file. DVD Author recognizes the program in it, but when I hit "Next" to edit or re-author the file, I get a pair of error messages:
*The video sequence header is incorrect.
A video sequence header is necessary for every GOP in a standard DVD.What I did was record a program to a disc that had been formatted using VR mode on my Pioneer DVR-220 recorder. Now I'm stuck.*The video GOP is too long.
For a standard DVD it is necessary that the GOP fulfill the following condition:
Max 36 fields (18 frames) (NTSC format only)
Max 30 fields (15 frames) (PAL format only)
Any ideas?
Tabe -
When formatting a disc for recording on the Pioneer, choose Video mode instead of VR mode. This will create VOB files from the start instead of VRO files. You will have to finalize the recorded disc before it can be used in another machine or your PC. DVD-RW's can be re-formatted and used over and over.
You will avoid some of the problems you are having by recording in the DVD-Video format... sometimes VR format recordings can be a little buggy, depending on your particular setup.
As far as getting your VRO files that you already have saved to your hard drive to work, you could try re-naming them with the MPG file extension and then authoring the file into a DVD. Your authoring program may be more forgiving with MPG files.
You might also try re-saving the file with something like ReStream... that may straighten out the file errors for you without re-encoding the file. -
I normally do use Video mode. However, when I tried to record this particular VHS video, I got a message saying it could only be recorded in VR mode.Originally Posted by gshelley61
Tried that, without successAs far as getting your VRO files that you already have saved to your hard drive to work, you could try re-naming them with the MPG file extension and then authoring the file into a DVD. Your authoring program may be more forgiving with MPG files.
I'll give that a try - thanks!You might also try re-saving the file with something like ReStream... that may straighten out the file errors for you without re-encoding the file.
Tabe -
A video sequence header is necessary for every GOP in a standard DVD.FYI I am trying to convert a Video VR disc (made on a Japanse Sony DVD recorder) and got the same error messages above. ConvertXtoDVD froze when I tried to access the .VRO file and I was unable to dub the VR titles using MY Sony DVD recorder (HX900, real-time dubbing produced blank screens w/o audio).*The video GOP is too long.
Is there an easy conversion tool for video VR stuff? Thanks for any help.
Problems Creating New Projects From .VRO/.VOB Source Disc
By RocknRollElitist in forum Video ConversionReplies: 0Last Post: 29th Oct 2010, 15:29 -
VRO conversion problems
By stellabelch in forum Video ConversionReplies: 3Last Post: 14th Oct 2009, 07:22 -
VRO to VOB Redux
By sambat in forum Newbie / General discussionsReplies: 4Last Post: 18th May 2009, 18:20 -
VRO o VOB
By natty in forum Newbie / General discussionsReplies: 5Last Post: 27th Oct 2007, 15:38 -
vro to vob on a mac x
By crocker5731 in forum DVD RippingReplies: 0Last Post: 18th Jul 2007, 21:14
