  1. how comes when i encode a movie in virtualdub and play it the audio is all distorted
    Nov 2002
    What kind of audio is it?
  3. I dont know what type audio is but here is a file info of movie from virtualdub
    Nov 2002
    Well, there you go. It says it's MP3. (MPEG Layer-3)
    How does the audio sound by itself? What if you demux the audio and play it back alone?
  5. how do u demux audio and is this done with virtualdub or another program btw audio is fine b4 u encode but after its been encoded its terrible all distorted
  6. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    You can do it with virtualdub (as well as a whole range of other programs).
    Is the audio just distorted when playing back within virtualdub, or are you playing in a media player (such as windows media player) ?
    You might try extracting the audio to a WAV:
    https://www.videohelp.com/guides.php?guideid=837#837
    http://members.dodo.net.au/~jimmalenko/ExtractAudio.htm
    Play the WAV and see if it is still garbled. If so, there might be a problem with the source file. If not, you should be able to specify this WAV as your audio source (by clicking on WAV Audio on the audio menu).
    If in doubt, Google it.
