    Apr 2003
    Few people have asked me weather this is possible, but not sure of the answer perhaps you guys could help me out?
    Nov 2005
    From my readings, you can read a PSP image, but you can't burn it just yet, because it's written under a file system that doesn't exist in the burning world just yet.
    Apr 2003
    Ah right, cause i've seen on some torrents site you can d/l a game, i take it, it would then be played on a emulator?
    I have also seen in the shops you can buy the plastic case that the disk would sit in
  4. Member Treebeard's Avatar
    Aug 2002
    umm ya you can download as long as you own the game already. better stear clear of piracy.
    Apr 2003
    no im not on bout copying i don't actually own a PSP i was just curious as ive seen the game and thought that they would be impossible to copy/burn
  6. Knew It All Doramius's Avatar
    Apr 2004
    If only I knew
    As stated above, You can only download a game that you already own or have purchased.
    As for copying & burning, I would say it is definitely possible, but again, it depends on the software that can properly burn the image to a disc with a file system the unit can read.
    Mar 2003
    You can boot the disk image from a memory stick duo
    You can save the disk image to memorystick, then send it to your computer and do a simple file transfer to put it back on your psp when needed via usb
    You need a umd dumper program
    you can google search to find what you need
    Mar 2003
    Also forgot to add if you want to be able to do everything you want
    your psp must have firmware version 2.0 and under (2.0 can be downgraded to 1.5)
    All homebrew can be played on the most current revision but if you want all your backups to play it must be 1.5 or 2.0
    You also need a loader program like umd emulator, fastloader, or hookloader installed to play backup images
