Hello does anyone know where i can find a guide or tutorial for the use of Subtitle Processor?????????
Bericht van tettenman.
Bedankt als je erop reageert!!!! -
Hi tettenman:Originally Posted by tettenman
I'm pretty new here but I think you might be able to find some tutorial information at http://sourceforge.net/project/showfiles.php?group_id=158915 (that's where I got the program from)
I have the program but unfortunately I can't add subtitles because even though I have the component "subtitlesource.ax filter" I don't know how to install it.
Good luck and hope my information was helpful.
Just copy the ax into Windows/system, where all the other AX files are, should do it, on, and type at a command prompt "regsvr32.exe /r subtitlesource.ax" to register it.
I just downloaded it and it appears to be something on the sophistication of Sub Station Alpha, but with a modern interface, with WAY more features than one needs. If you just need simple subtitle software, I recommend Visual SubSync or Subtitle Workshop.
Subtitle Processor - anyone know of guide to translate?
By dweeb52 in forum SubtitleReplies: 6Last Post: 15th Jan 2016, 09:27 -
Intel i5 2430M processor or AMD A8-3500M quad-core processor?
By jbitakis in forum ComputerReplies: 5Last Post: 11th Nov 2011, 20:31 -
Vertiggo's Subtitle Guide (if all you have is mkvmerge)
By vertigoanduminas in forum SubtitleReplies: 1Last Post: 7th Sep 2011, 22:15 -
TV Guide/Guide Plus+ After Feb. 2009
By handyguy in forum DVB / IPTVReplies: 0Last Post: 30th Oct 2008, 10:34 -
A question about Subtitle Processor
By tofuguy in forum SubtitleReplies: 2Last Post: 6th Oct 2008, 22:33
