Are some USB cables, USB 1.0 or are all USB cables capable of USB 2...???
The reason I ask is I have an older USB 1.1 cable and want to use it with a USB 2.0 device...
Ken
Some are, some aren't. It depends on the specs. You will know when you attach a high speed device via a low speed cable as windows will warn you about the transfer rate.
Try it.
The worst that can happen is that it doesn't work and you have to spend $5-10 (USD) to get a USB 2.0 cable.snappy phrase
I don't know what you're talking about. -
More info on USB cable already discussed here
https://forum.videohelp.com/viewtopic.php?t=274211&highlight=usb -
In relation to that linked topic I buy my extension cables in bulk lots of 10. These are generic USB2 made in china extension cables and when you buy in bulk you save on shipping. I can get 10 - 6 foot USB2 extension cables delivered to my door for $16. I don't need longer or shorter cables.
Is there any place someone knows of that I could buy them cheaper than this? -
cheaper than 16 dollars shipped? probably not.......that is pretty much rock bottom pricing on usb cables, unless your intending on buying in MASS bulk (like hundreds at a time) then maybe you can talk to a company that makes them directly and they can cut you some sort of deal..........but 1.60 per cable (averaging it out) isnt bad at all.....
That's what I thought but it never hurts to ask. In case anyone else is interested: http://www.newegg.com/Product/Product.asp?item=N82E16812116121
Never buy just 1, you save plenty by buying 2 or more. At 8, shipping is free. I provide these cables to anyone who buys an external drive from me or those needing an extension. -
You can never have enough cables. I always get USB, IDE, Firewire, SATA, internal audio, power, and other cords in bulk.
It sucks when you buy a refurbished optical drive and you realize after it comes you don't have an extra SATA cord hanging around. :/
looking for usb power only cable
By aedipuss in forum ComputerReplies: 8Last Post: 23rd Nov 2011, 12:49 -
Samsung micro USB-B to USB-A cable
By luigi2000 in forum Newbie / General discussionsReplies: 2Last Post: 13th Aug 2011, 14:05 -
USB Cable - cut off
By cal32 in forum ComputerReplies: 5Last Post: 8th Jan 2010, 07:27 -
Usb cable issues?
By alintatoc in forum Off topicReplies: 7Last Post: 17th Jun 2009, 03:14 -
firewire to usb 2 cable
By pavilion1250 in forum Video Streaming DownloadingReplies: 2Last Post: 15th Apr 2009, 21:01
