just captured interlaced stuff via dvb. want to convert it to xvid whats now?
deinterlace, o leave it interlaced?
when i want do deinterlace it, how to proceed?
darling if there is no place for me on your desktop, i'll waiting for you in the system tray
xvid is probably mostly played on the computer and then you should deinterlace it to look good.
XviD does also support interlaced encodings but then you must remember to not resize vertically and it should only be played on a TV to look good if encoded to interlaced format. The media player on a PC does normally not deinterlace interlaced XviD.
Can an interlaced file appear not to be interlaced on the monitor?
By rcavanah in forum Authoring (DVD)Replies: 5Last Post: 10th Sep 2011, 22:09 -
Converting DV to H.264 and comparing interlaced/de-interlaced
By amirh1 in forum Video ConversionReplies: 5Last Post: 23rd Jun 2010, 09:16 -
Convert interlaced HD to interlaced SD with AVISynth
By jorbje in forum Video ConversionReplies: 19Last Post: 22nd Mar 2008, 18:48 -
blur stuff out?
By zookeeper525 in forum EditingReplies: 8Last Post: 3rd Feb 2008, 07:52 -
menus and stuff
By zinc in forum Video ConversionReplies: 4Last Post: 8th Dec 2007, 08:51
