Just got my minidv and my firewire card is on the way, but I want to be ready to go when it gets here so whats the most basic capturing software out there thats the easiest on your pc memory? Also, can you select what part of a vid you want to transfer to your pc. In other words if I have a full hour long tape recorded, and I only want maybe 10 mins of it on my pc can I just select that part? Oh, one more thing, but I think I already know the answer from all the reading I have done. Is there anyway to compress the vid to a smaller size before you put in on your pc?
WinDV would be a good choice for DV transfers. Type 2 works best with most programs.
Because the DV is on a tape, you would just have to play the part of the tape you wanted to transfer if you didn't want it all.
The camera sets the format. It's DV, you can't change that. After you get it on the computer, you can encode it anyway you want. DV is about 13GB/hour, so make sure you have enough hard drive space.
I use VirtualDub Mod for edits and filtering. You need the Panasonic DV Codec or similar for this. Then you can frameserve it to an encoder or just use VDM if you want to encode to a different AVI type format.
Absolute newb confusion. Buy a digital camera.
By Early Grace in forum Newbie / General discussionsReplies: 6Last Post: 29th Sep 2010, 16:49 -
what's the absolute funniest movie you have ever seen?
By deadrats in forum Off topicReplies: 15Last Post: 7th Jun 2010, 21:13 -
The absolute best method to convert to AppleTV?
By DiGNAN17 in forum Video ConversionReplies: 10Last Post: 26th Aug 2009, 01:05 -
an ABSOLUTE, GUARANTEED 100% backup method using-it's NEVER failed for me!!
By fonzbear2000 in forum User guidesReplies: 25Last Post: 21st Oct 2007, 22:08 -
What is the ABSOLUTE BEST quality DVD ripper?
By Saif in forum DVD RippingReplies: 8Last Post: 17th Sep 2007, 20:31
