  1. Member adam's Avatar
    Sep 2000
    Maybe everybody already knows this and I'm the last to discover it, but when using Epson PrintCD you can change the media type from CD/DVD to CD/DVD premium surface and it makes a huge difference in quality. I know alot of people complain that the silver printables don't look vibrant enough, well I really think this solves that problem. Now my silvers look just as good as my white surface discs but it still has that hologram appearance.
    The program says that its not compatible with all discs and that drying takes longer but its worked on my TY's both white and silver.
  2. [url=http]text[/url] Denvers Dawgs's Avatar
    Feb 2003
    Right Behind You. . .
    is there is dramtic difference in the white printables using this option as well, or mainly just on the silver?
    What We Do In Life, Echoes In Eternity....
  3. Originally Posted by Denvers Dawgs
    NO, white looks the same.
  4. Member adam's Avatar
    Sep 2000
    Well white is not the same for me. Its not as dramatic a difference as with the silvers but it is still noticable, mainly with black. Without it black appears almost more like brown. Its just not very deep. This setting fixes that.
  5. Which is less likely to smear, white or silver?
  6. Member adam's Avatar
    Sep 2000
    I don't notice any difference myself. Either will smear easily if gotten wet and the oil of your fingers alone will smear it a bit if you apply much pressure. The silvers do get fingerprints very easily though and they are actually very hard to get off.
  7. Originally Posted by adam
    The new epson R220 drivers are a little different from R200, but I'm still able to print how I use to. On the R220 you have to select manual print to get to these settings
    I found these setting to be the best for my DVD/CDs
    Originally Posted by jagabo
  8. Anyone know a good setting for saving ink but still getting a fairly good image on a disc? I currently have it on photo quality on photo paper. Looking for some opinions.
