i've been using cue splitter v.05 but seems it doesn't support .ogg format what other free-ish .ogg audio file splitters are there.. preferably noobie-friendly thanks
I believe Audacity can open them, not sure about splitting, but it's freeware.
And you can check the Vorbis site for other software info:
http://www.vorbis.com/ -
If they were chained, then oggslit would work. Otherwise I don't know. I would have thought that liboggz would have included a tool for splitting, but it doesn't.
how do you convert .ogg audio file to mp3?
By shun in forum AudioReplies: 5Last Post: 22nd Sep 2023, 16:34 -
AVI - audio remove, video split, music merge
By kj1983 in forum Newbie / General discussionsReplies: 1Last Post: 29th Apr 2012, 03:59 -
Magix Music Maker - function to split vocal tracks?
By Artas1984 in forum AudioReplies: 4Last Post: 11th Sep 2011, 19:52 -
AC3 music/dialog is split. Any way to combine the two?
By silvertoaster in forum AudioReplies: 1Last Post: 23rd May 2011, 19:34 -
how to split mkv file and subtitle file to play on blu ray via hdd usb
By julie_152 in forum Newbie / General discussionsReplies: 1Last Post: 29th Sep 2009, 12:28
