I am setting up a computer to record short wave programming on my computer and am looking for something to filter out pops and hisses. Do you think Audacity would be suitable for that?
For hiss reduction, you can use the low pass filter and kill some of it. Pops are a little harder. You can limit the overall level, which may reduce the volume of a pop, but not eliminate it.
The type of audio you are working with is usually narrow bandwidth, so can be filtered without as much quality loss as something like DVD audio.
There are probably also some active filters that may be able to reduce some of the noise. These would be used on the audio out of the receiver.
But give the Audacity a try, it's freeware, so you have little to lose but a some time.
Some sites you might visit. The first should have info about filtering, the second is a PC audio filter program:
http://www.hard-core-dx.com/index.php?topic=SWB
A program for shortwave audio filtering:
http://www.winternet.com/~swezeyt/dsp/dspMtReview.htm
Filtering during MPEG capture
By TB Player in forum Capturing and VCRReplies: 9Last Post: 31st Dec 2010, 19:53 -
Audacity help
By efiste2 in forum AudioReplies: 3Last Post: 5th Aug 2010, 14:59 -
need some help with audacity
By shashgo in forum AudioReplies: 7Last Post: 16th Jan 2009, 02:21 -
Questing about filtering with one of your guides
By Oni87 in forum Newbie / General discussionsReplies: 6Last Post: 21st Oct 2008, 18:26 -
temporal and spatial filtering
By snafubaby in forum Capturing and VCRReplies: 2Last Post: 6th Oct 2007, 11:23
