trying to back up my sopranos
the only disc i'm having problem is season5-disc2
dvd decrypter had problem ripping it,
so what i did was:
1st try = ripped it dvdfab (success)+ authored it w/shrink + dvdrebuilderpro 1.06 = same problem shown below
2nd try = after the shrink + use shrink to change it to iso + mount to deamon + re-ripped it again w/ dvd decrypter = still same problem shown below
what's should i do now???
the "D2VAVS" folder was already created
Not Sure if the Pro Version will fix this problem.
By Wakewatcher in forum SVCD2DVD & VOB2MPGReplies: 5Last Post: 16th Jan 2011, 12:34 -
A Pioneer DVD fix it problem
By kenmt in forum DVD & Blu-ray RecordersReplies: 6Last Post: 23rd Jul 2010, 08:03 -
What's the right way to fix a field order problem?
By brassplyer in forum EditingReplies: 13Last Post: 28th Dec 2009, 10:03 -
Researched No Fix - Sync Problem
By waynepixel in forum Newbie / General discussionsReplies: 2Last Post: 30th Jun 2009, 13:30 -
Does WinXP fix a known Win2k problem?
By bevills1 in forum ComputerReplies: 6Last Post: 28th Feb 2009, 23:34
