Hi All,
I am compiling my vacation video and would like to put everything into 1 disc. It's about 6+gig. My Pioneer 110 should be able to burn DVD+R DL.
Here is my plan.
1. Use DVDLab Pro to author. Usually, I compile to Video_TS folder. In this case, I burn to hard disk in ISO format. Not sure if I should set the layer break at the Pre-mastering in DVDLab Pro. I notice that layer break setting there.
2. Use PgcEdit to set layer break ?
3. ImgBurn to burn to a DVD+R DL. Should I use DVD Decrypter instead, since I already have it in my PC ?
Thanks in advance to your help.
well. for one you will have to use a bitrate of approx. 2800 which is reeeeally low. So, you will need to adjust your resolution to half d1. If the source is good and clean you might get a decent result.
@ greymalkin,
I don't intend to adjust the bitrate. My plan is to burn to a DVD+R DL. -
I would use Sonic RecordNow(7 or 8 ),Prassi Ones or Imgburn.If you use Imgburn make an ISO first with ImgTool Classic.
Burned home-video DVD looks not deinterlaced on tv
By granturissimus in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2011, 09:59 -
Need advice to make my own home video/DVD
By Vidnewbie1 in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2010, 12:30 -
Copying some home video on VHS to DVD
By syilim in forum Newbie / General discussionsReplies: 1Last Post: 4th Nov 2008, 21:23 -
home video to dvd: resolution issues
By hickmanbetty in forum Newbie / General discussionsReplies: 2Last Post: 6th Jun 2008, 11:56 -
Home Video to DVD no sound
By nixacrew in forum Newbie / General discussionsReplies: 2Last Post: 2nd Feb 2008, 11:06
