my khypermedia burner just recently started taking up to ten min to iniatialize to start burning a cd, i tried lower speeds but the sme thing happened any help would be appreciated.
What type of files are you trying to burn (image, data, music)? Have you changed media? What type of media? Does it burn fine after it starts? Do you have enough free space on your drive? Is your drive defragmented? Have you added / changed any software or drivers recently?
I would love to help, but you haven't given nearly enough information.Google is your Friend -
Im trying to burn audio cds and i havent changed media, the media is also khypermedia i have 100+ gigs of hdd and the i have added poweriso in the software category while hardware remains unchanged.
what software are you using to compile/burn the cd?
Do you have the same symptoms when you try to burn a data disc? Is the burn time and/or speed normal after it starts burning?
I would expect what you are seeing is the time it is taking Nero load and convert the audio files. This could be caused by a fragmented drive, other processes running at the same time, or just Nero flaking out.Google is your Friend
CDRW Erasing Cancelled - CDRW NOT WORKing
By Sarao in forum ComputerReplies: 6Last Post: 5th Feb 2010, 11:55 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
Really slow external hard drive. WTF?!
By dafoe in forum ComputerReplies: 8Last Post: 25th Sep 2008, 04:19 -
New Comp slow startup time
By WinSpecToR in forum ComputerReplies: 20Last Post: 12th Jul 2008, 19:09 -
Encoding with VirtualDub the second time around is very slow
By Megahurts in forum EditingReplies: 9Last Post: 7th Mar 2008, 00:02
