    Mar 2003
    Malta
    An mpeg file has the audio in english but it is repeated again in Turkish. Is there a way I can fix the audio to hear it in english only?
    Hello from the island of Malta.
  2. Member Cornucopia's Avatar
    Hello Malta!
    Get TMPGEnc. It cost to use to convert to MPEG2, but you won't be doing converting, just demuxing/remuxing, so that's cool.
    Assuming what you have is 1 video stream, and 2 separate audio streams, just demux all 3 streams and then remux only the video and the audio stream that you want. Done.
    If, however, you have only 1 audio stream and it has Engl. on "Left" channel, and Turkish on "Right" channel (or vice-versa), then you'll have to open up the demuxed audio stream in an audio editor (Goldwave, Audacity, etc) and remove/remix to the desired channel.
    Then re-encode your audio (to Mp2 or AC3) and remux with the video.
  3. Banned
    Freedonia
    If you have the infamous "voice over" which I have discussed here:
    https://forum.videohelp.com/viewtopic.php?t=294581
    there is nothing you can do about that. I have no idea whether Turkey uses this "technology" or not, but it was used all the time in the USSR and is unfortunately still sometimes used in Russia.
    Mar 2003
    Malta
    How do you demux all three streams,pls?
  5. Member Cornucopia's Avatar
    TMPGEnc.
    [File | MPEG Tools...]
    TAB--[Simple Demultiplex]
    Load you source file, it will autogenerate appropriate extensions for the demuxed streams.
    BTW, "Demux" = "DeMultiplex". Just a contraction. Just like "Mux" = "Multiplex"
