chrissy
i just loaded in an 11gig .ts file but final output will be 7gig, my question is does the converted dvd output to true HDTV res/ar of 1080 as in the source or does it convert to something less hi-def
hope you understand that m8
sc0tsman
A normal DVD is created as per the DVD specs: i.e. 720 x 480 pixels.
In short the requirement for HDTV2DVD is to reduce the usual high HD bitrate to within the DVD specs: <9000kbs and to change the video resolution to that of the DVD specs: 720 x 480 pixels.SVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
Quick Question
By TagFan in forum DVB / IPTVReplies: 3Last Post: 26th Sep 2011, 09:45 -
LG CH08LS10 just a quick question or two ?
By MidnightMike in forum DVD & Blu-ray WritersReplies: 9Last Post: 13th Nov 2010, 04:51 -
Quick Question About My TV and HDMI
By SnoopKatt in forum DVB / IPTVReplies: 11Last Post: 9th Jan 2008, 17:03 -
quick question?
By JRSWIFEY2004 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2008, 16:38 -
Quick Question
By Scryer_360 in forum Newbie / General discussionsReplies: 3Last Post: 26th Dec 2007, 07:21
