hi all, i am new to the forum and am impressed on the site. well i just bought serif movie plus 4 plus the effects studio and for me this is incredible, the things i can do with video is just amazing. well my exact question is what codec would be best to capture tv to hard drive but still keeping the file size moderate. i just learned that movie plus struggles with a file over 1gig. thanks all and glad to be here
Render it in 3D
What capture card do you use?
Unfortunately, quality and small (moderate) file size is mutually exclusive. If you're going to make some edits of your captures, use as uncompressed format as possible when capturing. Take a look att Huffyuv if your card captures to AVI.
/Mats
convert video with Photo JPEG codec and MS IMA APMCD audio codec
By devil_doll in forum Video ConversionReplies: 3Last Post: 21st Jan 2011, 14:10 -
Which Codec's is Best To Use?
By Artic in forum Video ConversionReplies: 4Last Post: 26th May 2010, 14:39 -
Can Codec ID/Codec Hint make a difference on the video?
By dzsoul in forum Video ConversionReplies: 2Last Post: 1st Jun 2009, 19:40 -
MPG File with ivivideo Codec-bad picture.Can I change the codec?
By cska133 in forum Software PlayingReplies: 13Last Post: 4th Nov 2008, 09:41 -
BD Codec?
By kinglerch in forum Blu-ray RippingReplies: 4Last Post: 1st Aug 2008, 20:26
