This box is working good at reading and writing disks, doesn't matter what kind and I can watch them on my other dvd player. The one problem I would love to fix is the screen gets real bright when a bright scene or sunlight is present. The service tech emailed me back and said might be tuner circuitry and exchange it which I did and it is the same. I wonder if there is a way to record from the tv through the front connections and if that might fix the bright problems? Maybe run it to the vcr then out to tv and out to the recorder. Has anyone figured this out or have any suggestions.
Thanks for all the good info
These use cheap mono tuners. Best is to record directly to the svideo or composite video inputs and bypass the tuner. That's the only way to correct for difficiencies in these cheap recorders...
Ilo DVDR04
By 2003 Hayabusa in forum Newbie / General discussionsReplies: 4Last Post: 2nd Sep 2010, 14:48 -
Need files to update ILO DVDR05/ZU cant find anywhere
By strbyz1 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 22nd Aug 2009, 21:48 -
Ilo DVDR04 replacement drive
By emyly7 in forum DVD & Blu-ray RecordersReplies: 11Last Post: 21st Aug 2009, 03:12 -
ILo dvd recorder not cooperating
By jhayes in forum DVD & Blu-ray RecordersReplies: 9Last Post: 9th Dec 2007, 10:06 -
Feeding ilo DVDR05 output directly to PC, is it possible?
By superspeedfreek in forum DVD & Blu-ray RecordersReplies: 3Last Post: 4th Jun 2007, 12:43
