Hi,
I want to join 3 AVI files, say, file A,B,C
I follow the procedure in your guide, which is also the same reported in other websites, but I cannot succeed.
Here what happens.
I open A, then append B, then append C then Video Direct Stream and finally save as AVI.
I get, A+B+C+B
The strange thing is that I can see in the bottom slider the right file size, every file is in fact 250 MB, so I see 750, but when it saves the estimated file size is 940MB.
I thought it was a bug in 1.6.11, then I tried 1.6.13, but same problem.
Ideas?
Alex
AOPEN AX34, PIII 1.0 GHz, 1,5GB RAM, HD WD 120 GB, Pioneer DVR-116D, Plextor PX-716A, HIS Excalibur Radeon 9600, 256Mb, 2xMonitor Philips 109P20 Br Ethernet D-Link DE-828CT, Philips ToUCam Pro, WXP PRO SP3
try join two at a time, a+b and then ab + c.
and contact virtualdub about the bug, http://virtualdub.org/contact -
Do you know that VirtualDub automatically appends sequentially numbered segments? Is it possible that B in your example is being auto-appended because the name is "1" more than than C?
For example when appending these three files in this order:
FILEA.AVI
FILE2.AVI
FILE1.AVI
FILE2.AVI will automatically be appended (unless you disable the "Autodetect additional segments by filename" option in the file append dialog) after FILE1.AVI is appended, giving four files instead of three. -
Don't you have to manually enable auto appending?
edit: not in newer versions... -
The additional frames and running time on the seek bar don't fit in with the hypotheses but I thought I'd mention it.
Hi,
jagabo is right, that was the reason of my problem.
That option is a bit strange to me and really you do not notice it unless somebody tells you.
I have unchecked it and now it works!
Thank you very mcuh for your tip.
Regards
AlexAOPEN AX34, PIII 1.0 GHz, 1,5GB RAM, HD WD 120 GB, Pioneer DVR-116D, Plextor PX-716A, HIS Excalibur Radeon 9600, 256Mb, 2xMonitor Philips 109P20 Br Ethernet D-Link DE-828CT, Philips ToUCam Pro, WXP PRO SP3
[Resolved] Making 2 AVIs the same so that VirtualDub can append?
By Diana (Cda) in forum DVD RippingReplies: 32Last Post: 9th Dec 2010, 14:01 -
Help:VDUB:CANNOT APPEND SEGMENT segment has a different number of streams
By lil_Dee in forum EditingReplies: 9Last Post: 23rd Jun 2009, 08:16 -
virtualdub append question
By thecrock in forum Newbie / General discussionsReplies: 2Last Post: 6th Dec 2008, 10:30 -
Cannot append some AVI files in VirtualDub.
By StehpenRH in forum EditingReplies: 3Last Post: 8th Oct 2008, 04:51 -
Problem with Append AVI in VirtualDub - Audio of Sync - How Fix?
By Chakra in forum Newbie / General discussionsReplies: 3Last Post: 6th Aug 2008, 18:00
