my dvd burner wont play or burn any dvd discs since i last updated it firmware,it still burns and plays cds,cdrs,and cdrws,my burner is a nec 1300a and firmware is 1.0c,when i put a dvd into the tray and close it it makes this clicking sound and looks like it is going to play then stops,and when i try to burn a disk it says please insert an empty medium to write to.
any ideas what is wrong please
sorry i should of said i did downgrade to 1.0a and its still not working
Try an actual pressed DVD (store bought software / movie). If it can't read it, then it's most likely a hardware issue and time to get a new drive. Most of the drives use seperate lasers for cd and dvd. Also, usually when there is a problem with a firmware upgrade/downgrade, the whole drive becomes unusable, not just part of the drive.
Google is your Friend -
More than likely this 4x4x16 single layer writer has seen it's day and the sun has set.
File wont play from memory stick but will from disc
By muay in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Jan 2011, 08:11 -
Multiavchd disc wont play in PS3
By cougarve in forum Authoring (Blu-ray)Replies: 28Last Post: 30th Aug 2010, 09:28 -
Optiarc AD5170A 1.13 Wont burn 'disc at once' any ideas?
By surfmonkee in forum DVD & Blu-ray WritersReplies: 1Last Post: 17th Jan 2008, 11:44 -
Dvd Burner Wont Copy
By Catman209 in forum DVD & Blu-ray WritersReplies: 12Last Post: 16th Dec 2007, 00:35 -
Ive copied a avi disc but it wont play on my dvd player
By popeye39 in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2007, 16:26
