I had a few avi files that wouldn't open in TMPGEnc3.0 XPress. When I tried to open these files, I would get a message sayting that only the audio could be opened. Checking the files with GSpot, I found that I apparently needed the xvid codec. I installed it. One of the files now apparently opens just fine and can be edited.
However, when I try to open the other file, the "audio only" message no longer appears, and the program seems to go thru all the proper motions of opening the file, BUT only the audio opens. There is no picture to be seen, only a black screen.
Is the problem with the codec? Or with that particular file maybe?
Help?
Results 1 to 1 of 1
TMPGEnc 4.0 XPress XVID Compression Confusion & Archival Suggested Setting
By timmer545 in forum Video ConversionReplies: 4Last Post: 26th Mar 2011, 10:54 -
Recording with high quality and good conversion methods (snagit & codec q.)
By mukunku in forum Newbie / General discussionsReplies: 7Last Post: 13th Apr 2010, 23:43 -
MEncoder Crash on WMV & Possible Codec Problem!?!?
By gonwk in forum Video ConversionReplies: 0Last Post: 8th Mar 2009, 19:15 -
Help.... Conversion & Author Problem with TMPGENC Xpress V.4.4.1.237
By milindb1 in forum Video ConversionReplies: 19Last Post: 22nd Sep 2008, 02:40 -
Best container & codec for FLV conversion to DVD
By Dsypher in forum Video ConversionReplies: 12Last Post: 21st Aug 2007, 14:53
