I just tried to burn burn some video files using Nero, but for the first time encountered audio lag on the DVD it produced. ( ihave used Nero problem free in the past)
From what I have read this is a big problem with a lot of authoring software, so I wondered if the best chance of producing a working DVD with no audio lag, would be to use TMPGEnc DVD Author 1.6 instead.
Is this likely to solve the problems?
Thanks in advance for any help
When I check the properties it just says Video clip.
The summary of the clips provide the following details
AUDIO
Bit rate: 130 kbps
Audio Format: MPEG Layer-3
VIDEO
Frame Rate: 23 Frames/second
Data rate: 142 kbps
Video Sample Rate: 12 bit
Video compression DivX codec
These files play fine on my pc, but when burned to DVD the problem occurs!!
Will I be able to author these using any of the tools mentioned? -
Tried that software you suggested, worked a treat. Thank you for your help baldrick.
Final Cut Express audio sync
By EagleAye in forum MacReplies: 4Last Post: 24th Apr 2012, 19:39 -
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
Nero 7 audio sync problems
By CRJ705driver in forum Authoring (DVD)Replies: 5Last Post: 26th Sep 2010, 03:25 -
Recording audio with Nero Vision 4 Express
By SEE_Studios in forum AudioReplies: 3Last Post: 21st Jan 2008, 16:28 -
Sudden problem with Nero Vision Express 3.1.0.0
By smackyourfupa in forum Authoring (DVD)Replies: 8Last Post: 3rd Nov 2007, 17:56
