Hi All,
I have searched all over many forums for an answer but yet to get a definitive one.
I have two stand alone DVD players that are DivX certified and too date I have had little/no problem playing any files, recently this has changed, although all of these files play on my PC some newer ones are not playing on my standalones - FIRMWARE I here you all scream, but been there and tried that with no success - for ref the standalones are;
Ellion DVD-520C Mpeg-4 Player
Shinco - SDP-1850
I thought this could be a Codec issue and used AVICodec to try and find a trend, think I've found it.
All files without exception are on the Xvid Mpeg-4 codec, the difference being that the files that won't play have a different Audio Codec, the ones that are fine are - MPEG Layer-3 - the ones that won't play are AC3 DVM.
Is this just a coincidence or the cause of my problems and if it is how can I re-encode the audio to MPEG Layer-3 as I know this works fine.
Thanks in advance
Use MPEG4Modifier to check the MPEG4 files for GMC and QPEL -- two optional features of both Xvid and Divx that most set-top players can't handle.
If that's not a problem then the AC3 audio might be. It's easy enough to convert the audio to MP2/3 without reencoding the video. With VirtualDub:
File -> Open Video File
Video -> Direct Stream Copy
Audio -> Full Processing Mode
Audio -> Conversion (change to anything you want)
Audio -> Compression (select MP2/3 codec and parameters)
File -> Save as AVI. -
There is also a divx test cd here: https://www.videohelp.com/dvdplayers
This will help you find out which files your players can handle.Google is your Friend
H.264 mpeg-4 problems playing back
By jedis in forum Video ConversionReplies: 2Last Post: 23rd Mar 2011, 23:00 -
Why Is Playing Back .mts Files From A Camcorder On HDTV Better Than A PC?
By JohnnyGalaga in forum Newbie / General discussionsReplies: 6Last Post: 15th Jan 2011, 14:00 -
How to join back 2 xvid files encode by autogk
By warresg in forum DVD RippingReplies: 1Last Post: 6th Nov 2010, 02:59 -
Problems playing Divx / Xvid files on Silvercrest KH 6508
By Onihoshi in forum DVD & Blu-ray PlayersReplies: 7Last Post: 11th Oct 2008, 15:18 -
DVD Extras Not Playing Back in Standalone
By SamNZDat in forum Newbie / General discussionsReplies: 2Last Post: 16th Nov 2007, 03:29
