  1. whats best way to put images on a cd so you can view them with names on the images on a home dvd player ie: so when looking at pictures on home dvd player you can also see text as whats picture about
  2. Banned
    Feb 2005
    USA
    Add text to the picture and burn these edited images to a data cd.
    Nov 2002
    Or, slide-show vcd
  4. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    At least go with a slide Show SVCD....pictures on a VCD look so crappy.
    Feb 2004
    Australia
    Dvdslideshowgui can do all of this ... but it create's video file's ... you tell it what transition's , and time between each clip is , and it produce's the video .
    Best thing is it dosent muck with the size format of you picture's , ie , no sqeezing or stretching them out of shape .
    If you want to beable to use the remote to control the playback of each clip as individual item's .. that is a little more envolved , and require's .
    Ifoedit , vobedit , pgcedit , virtualdub , notepad ... that's the work's .
    Dvdauthorgui and the gimp for creating the menu's and basic dvd authoring .
    Which remind's me to finish another guide for pgcedit soon .
    Dvd on cd is known as minidvd ... you will need to check if your player's support the playback of such item's .
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    VCD supports 704x480/576 still pictures.
    A VCD slideshow creator like Photodex Proshow would proabably be easiest.
  7. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    DAMMIT Baldrick....I wanted to go one day without learning something new...
    Thanks for the tip though....
  8. thanks all for wonderfull replies
