I have 10 mpeg videos that i want to combine into one dvd. I am using a powerbook g4 with iDVD and iMovie. I also have Roxio Popcorn software. Does anyone know how I can combine all the mpeg videos to make one dvd?
Hi, I've done several mpeg DVD's using Toast 6 and it will create menus if you want it to. They usually turn out quite well. You didn't mention having Toast but it works. I'm a Movie Trailer and short clip Collector. I know I'm alittle nuts! It takes forever to encode an MPEG clip on my 533 Dual. I usually just let it do it overnight and it's done by the next morning.
mpgtxwrap will take individual mpegs and merge them into one big mpeg.
you can then drop that into toast and author your dvd. Or you can even demux it and then use sizzle to compile a dvd is you like. there are many choices.
you can even take the output from mpgtxwrap, convert to dv with quicktime and then import to iMovie and go that route if you like.
the sky's the limit.
dvd copying
By ruthann in forum DVD RippingReplies: 9Last Post: 26th May 2011, 17:57 -
Copying a DVD
By grominnetto in forum Video ConversionReplies: 5Last Post: 17th May 2010, 20:31 -
Copying Speed Slows Down as Copying Progresses
By Soopafresh in forum ComputerReplies: 3Last Post: 25th Sep 2009, 21:03 -
Copying A DVD
By Nitro89 in forum DVD RippingReplies: 28Last Post: 25th Feb 2009, 13:53 -
Copying DVD's
By lsvtec in forum DVD RippingReplies: 2Last Post: 16th May 2008, 03:06
