Went to convert a avi to dvd and didn't save the source (1st mistake)...
I had checked the avi and it seemed fine for sync which was why I made mistake 1.
later I went to convert to Mpeg2, after extracting audio to wave file, TMPGEnc Xpress converted fine, apparently. Checked the file by playing it and towards the end it was was out of sync despite being fine earlier on...
Said hmmm... Converted again, same thing. Tried DVD Santa & CCE Basic, both crashed, big clue.
End result corrupt avi at approx 17 minute mark. So I took the Mpeg2 used VideoReDo to split at the bad point used it's audio sync tool to adjust the audio and then took the two separate mpegs to use for authoring.
So if I use Vdub to repair will that keep the audio sync next time? I must be having a senior moment because I could not figure out how to use vdub to repair.
Many Thanks
Results 1 to 1 of 1
General Cable question
By acrumbacker in forum Newbie / General discussionsReplies: 5Last Post: 1st Jan 2011, 22:00 -
can someone answer a general aspect ration question to me
By consumerx in forum Newbie / General discussionsReplies: 4Last Post: 1st Nov 2010, 11:58 -
General question about blu ray files and HD
By True Colors in forum Newbie / General discussionsReplies: 8Last Post: 22nd Dec 2009, 18:23 -
General question: best practices to create/generate a preview
By nickman00 in forum LinuxReplies: 2Last Post: 14th Jun 2009, 04:43 -
General Bluray \ HD question
By Shayetet13 in forum Newbie / General discussionsReplies: 6Last Post: 7th Oct 2008, 03:08
