I'd like to make a DVD-ROM of my music that plays on both platforms. I know there's a few programs out there but can anyone tell me the most cost effective way to do this? Basically all my ROM has to do is launch a .html file when inserted.
Autorun on the PC is easy, see my past posts on the subject. Be forwarned that many users may have turned off autorun, though.
Autorun on the Mac side is a NO GO. Because of an old virus that utilized Quicktime's autorun vulnerability, old Mac (preOSX) users basically turned off autorun En Masse. Because of it's compromised feature set, Apple decided NOT to include autorun in OSX.
You can do it for the PC (and I could tell you how to do it for old Macs if you REALLY want it), but I'd still recommend you put a ReadMe.txt on the disc explaining what to do manually.
Scott -
thank you. can you explain to me then why there are a few programs out there priced around $60 that create hybrid volumes? Macimage is one.
Hybrid volumes made more sense in the pre-DVDwritable, pre-UDF days. Since all modern OS's support UDF, and it's not a "Lowest Common Denominator" like ISO9660 was, it should be able to do the trick for ALL the OS's.
However, there are still times where it makes sense.
1. Legacy OS compatibility (DOS/Win3.1/Win95 and MacOS 7-9)
2. Specialty OS features, such as MacOS's custom icon & desktop settings, are correctly/better supported in their native FileSystem than in UDF.
3. Sometimes specialty partitions, like Shared+Compartmentalized data, are easier to do with those more traditional tools. You mentioned MacImage, but Toast is another.
Obviously, if you're going to DVD, you are supposed to use UDF, but there's nothing stopping you from making a 3- or 4-filesystem image (UDF+HFS+ISO9660+Joliet). That should certainly cover all the bases.
Then it's just a matter of knowing which OS sees which Filesystem as their "preferred/default" layout.
Scott -
Originally Posted by Cornucopia
Thanks for your time with this issue. You seem to know a lot about it. I decided to just make the ROM normally and then put explicit instructions on the packaging for Mac users.
Autorun Powerdvd in MCE2005
By alucard2050 in forum Software PlayingReplies: 0Last Post: 23rd Feb 2010, 19:30 -
software recomendations to make an autorun CD
By julitomg in forum ComputerReplies: 2Last Post: 23rd Jun 2008, 15:46 -
Autorun Precedence - DVD & Autorun on the same disc
By SCDVD in forum Newbie / General discussionsReplies: 1Last Post: 15th Aug 2007, 20:26 -
How to make an autorun VCD in English please!
By jimiir in forum Authoring (VCD/SVCD)Replies: 10Last Post: 8th Aug 2007, 22:56 -
DivX on DVD Autorun Software
By Burgos in forum Software PlayingReplies: 0Last Post: 31st May 2007, 09:13
