A VCD to DVD can play up to 250mins. If i compare with DVD which would have better quality? if DVD played for 250mins.
At VCD resolution, you can put around 7 hours or more on a DVD, much more than 250 minutes.
At half-D1 you could get 250 minutes on at a higher quality than you would get using VCD resolution. DVD at half-D1 would be the better option for that running time.Read my blog here.
DVD to VCD... HOW?
By aglara in forum DVD RippingReplies: 3Last Post: 17th Jun 2010, 00:29 -
VCD to DVD
By Argon in forum MacReplies: 4Last Post: 5th Oct 2008, 11:01 -
Will a DVD player play any files but DVD/VCD and CD audio?
By brassplyer in forum DVD & Blu-ray PlayersReplies: 3Last Post: 24th Sep 2008, 20:32 -
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
