  1. is there a way to change the frame rates of the file because im using this program and it cant convert the formate into dvd because the frame rates are wrong
    :D
    Apr 2004
    Miskatonic U
    What program ?
    What video format ?
    What resolution ?
    Details man, details. It may be possible, or it may be that the video is so far from compliant you need to re-encode. However, until you give us something to go on, you can't seriously expect a sensible answer.
    Read my blog here.
  3. In addition to guns1inger ... What EXACTLY you want to achive !
    When I was born I was so shocked that I could'nt speak for 18 months.
  4. im using the program "avi2dvd" for this one, if u have miltiple files you just need to rename them "Matrix CD1, Matrix CD2" and it will merge the files together. The type of files iv been using are .mkv ones and also .ogg.
    this isnt the only program - some times there are problems with the audio so i reencode it using virtual dub mod with works about 70% of the time
    :D
  5. Always Watching guns1inger's Avatar
    Apr 2004
    Miskatonic U
    Go back to your original DVD and make a new backup.
    Read my blog here.
  6. well the files were dled so i have no way of getting it, are there any other options to fix this problem?
    :D
    Apr 2004
    Miskatonic U
    Read the forum rules - you won't find any more help here
    Read my blog here.
