I downloaded a video in AVI format. Naturally, I assumed it would be DivX or Xvid compatible. But when I tried playing it in Quicktime, I got an error message. I tried it with VLC. The sound played fine, but there was no video. So I tried converting it with ffmpegX, but it kept failing, no matter what encoding format I chose (I tried standard MPEG-4 and DivX). So I looked at the info in VLC:
Apparently this new video codec is part of the MPEG-2 group, according to ffmpegX. My question: Is there anything I can download (codec, plugin, filter) to successfully convert the video to another format to view in Quicktime?
According to http://www.fourcc.org/ , http://www.microsoft.com/windows/windowsmedia/format/codecdownload.aspx might assist,
If in doubt, Google it.
AFAIK, the Quicktime WMV component only handles audio/video inside WMV/ASF files.
If you have the Pro version of the WMV component that allows for exporting, you can use WMV3Server to extract the separate tracks from the AVI file (it will save them to your home directory after being run) and encode the video to something else with QT Pro/other Quicktime app.
Ripping CD (Enhanced Video) Unknown Format
By SE14man in forum Newbie / General discussionsReplies: 1Last Post: 30th Jan 2011, 20:20 -
Unknown video colour noise / interference issue ... driving me mad!!!
By yakpith in forum Capturing and VCRReplies: 0Last Post: 30th Jul 2010, 06:59 -
Imposible to edit a AVCHD video
By Asrhael in forum EditingReplies: 14Last Post: 25th Jul 2010, 20:46 -
Capturing unknown format video 8
By Bigby in forum Capturing and VCRReplies: 17Last Post: 28th Sep 2009, 09:10 -
unknown codec, mov container
By jlz901 in forum Video ConversionReplies: 4Last Post: 1st Apr 2009, 19:25
