Whenever I author and burn a DVD from M2V source files that have a top-field frame type, the resulting DVD exibits choppy stand alone DVD Player playback. Reencoding the M2Vs to a frame picture frame type always fixes this but at a loss of quality. Is there a way to change the frame type without reencoding or perhaps another way around this? If not, what would be the best TMPGenc Plus 2.5 settings to use to minimize quality loss from the original M2Vs?
thanks
The current problem M2V files were demuxed (using rejig or DGIndex) from VOB files that were extracted and split by chapter using DVD Decrypter. DVDAuthorGUI ran into an error while authoring these particular VOBs so I demux them and DVDAuthorGUI outputs a Video_TS folder and I burn it using ImgTool and ImgBurn. That was how I created my newest coaster and I should have known better and checked the frame type before I started authoring. I have run into this same problem using TMPGenc DVD Author and its' burning tool with demuxed Vobs that haven't been split that were extracted from perfectly working DVDs. Its always the same variable (top-field frame type) that creates this problem on my set top DVD player (PS2).
You could try restream or DVD patcher. One or both of these should be able to change the frame order without re-encoding.
Read my blog here.
Restream will let you toggle between bff and tff but thats not what I'm talking about here. You'll notice that when you open an M2V with restream that right below the "top field first" box is something that reads "Picture structure:" and then it will say something like "top-field" or "frame-picture". It is only when this box reads "top-field" that I have this problem. Checking or unchecking the "top field first" box has no effect on the picture structure, I've tried it and it does not fix the problem. It looks like I will have to reencode.
Have a read of this and see if it fits what you are seeing
http://www.dvddemystified.com/dvdfaq.html#3.4
What sort of TV do you have ?Read my blog here.
I don't see anything in that article about what could be causing this, maybe I'm missing something. I don't see how my TV could have anything to do with it because I can hear the lens arm motor in my DVD player actuate in time with the skipping and chopping. It sounds like its trying to play a really scratched disk but there are no scrathes on it (obviously).
If the machine is working hard, I'd suspect poor quality media. Have you tried using Nero Speed Disk or DVD Info Pro to scan the disc and check the burn quality ?
Read my blog here.
Choppy video playback.
By Stealth3si in forum Media Center PC / MediaCentersReplies: 5Last Post: 2nd May 2014, 02:16 -
How to fix choppy video
By dexter30 in forum Newbie / General discussionsReplies: 1Last Post: 5th Aug 2010, 08:52 -
choppy video on blip.tv
By gtmb in forum Video Streaming DownloadingReplies: 3Last Post: 25th Sep 2009, 10:46 -
After conversion video is choppy
By 2112Video in forum Authoring (DVD)Replies: 1Last Post: 26th Aug 2009, 10:57 -
Choppy video with ConvertXtoDVD
By tuan209 in forum Video ConversionReplies: 1Last Post: 10th Jun 2007, 21:10
