I've been reading about intel binaries for mpeg2enc, mencoder, and mplayer that can be plugged into ffmpegx. where can I get the intel or uniBin mencoder and mplayer that I can use with ffmpegx 0.0.9v? I know that .9w is really close, but I need a temporary solution for my macbook pro until then. I've been googling around looking for them, but I can only find the intel versions bundled in a .app wrapper.
Major, Gotta give you props for all the work you do on this thing. ffmpegx is by far one of the most used apps that I have since I switched to mac a few years ago.
Results 61 to 89 of 89
From majors replies he changed so much in the original sourcecode of mencoder an all the other programms that normal versions won't work in ffmpegx any longer.
Tried it with h264 from an old isquint version - no luck, some command funktions are missing.
Sooo, since majors *cough cough* calculated hours are already way in the reds, i'm sure we'll see 0.0.9w during this week.
I just hope 9w will also recognise ".mpeg"....9v only likes ".mpg" - my big problem with streamclip.
Ahhh well, you can't have anything, perhaps i should learn automator.
Forgive me if this was already answered and I missed it.
Will the Universal version be multi-processor/core aware?
The current version, on both my Dual G5 and my Dual Core MacBook Pro, never utilizes more than 100% of the processor per encoding. It gets as high as 98% but never crosses the 100% mark.
If I encode 2 files at once, each on can use up to like 95%, so if I have more than 1 file to do I can maximize my productivity, but I'd love it if I could do 1 file twice as fast.
Just curious. Even if you never released another version and I had to use the PPC version from now on, it's still a phenomenal program. Bravo.
So unbundle the .app! Right-click on the .app you want to unbundle and choose "Show Package Contents". That will then allow you to browse the contents of the .app bundle. Normally you'll find executables in there for mencoder etc which you can just copy out using the Finder and put where you need them.Originally Posted by ammonkc
Thanks Major! this is awsome. ffmpegx was the last piece to finish pimpin out my macbook pro.
ffmpegX benchmarks
By Case in forum ffmpegX general discussionReplies: 0Last Post: 20th Aug 2011, 12:21 -
clarkdake encoding benchmarks!!!
By deadrats in forum ComputerReplies: 12Last Post: 6th Jan 2010, 18:38 -
lynnfield + tmpg express benchmarks!!!
By deadrats in forum ComputerReplies: 0Last Post: 6th Aug 2009, 21:20 -
first Core i3 benchmarks
By deadrats in forum ComputerReplies: 12Last Post: 2nd Aug 2009, 17:17 -
Core i7 benchmarks!!!!
By deadrats in forum ComputerReplies: 6Last Post: 3rd Nov 2008, 20:33
