Any luck on the ac3 issue major?
Results 31 to 60 of 89
Is this what your office floor looks like http://k41.pbase.com/u/slug/large/240.33.jpg ?
An interesting thing I have observerd recently with H.264 encoding, I have a Mac Mini Core Duo and an IBM Thinkpad R52 1.73Ghz that I use as an OS lab rat. On the Mac Mini I typically get about 17-19fps using Handbrake 7.1 x264 baseline profile encoding a movie 1 pass for a 700MB target size.Originally Posted by Case
When I tried the same test DVD, on the Thinkpad running Acidrip with the x264 mencoder codec under FreeBSD 6 and Ubuntu linux 6.06 I got a lousy 4-5 fps. However yesterday I installed the OpenSUSE 10.1-RC1 linux distribution and tried the same test and got 19-20fps constantly. So how can there be a 400-500% speed difference on the same hardware, there must be some processor feature the other distros missed? Does that mean there is more potential in the Mac Mini than Handbrake is achieving? Like I would be possible to see 30fps out of ffmpegX universal?
Most differences will depend on how the binaries are compiled and optimized, as well as on the source video being encoded (format, size, bitrate, complexity). As said above, on an Intel iMac I observed about 40fps on a test clip for the ffmpegX x264 preset (DVD to H264 at 640x272).
Quite right, sorry I missed that x264 test you did I only noticed the ones in bold at the top of the thread. 40fps is very good, the Mac Mini is slower but it will be in the right ball park. As you say the type of source video can have a huge effect on the results, I try to use the same DVD for my tests. I did notice on the linux version that some of the support libraries were tagged i586 and others were i686 in the SUSE linux, I presume they all used SSE in the x264 codec like you are doing.Originally Posted by major
For a comparison I am just installing the OpenSUSE 10.1 RC1 on the Mac Mini under Parallels Wokstation 2.1 beta 3 to see how the x264 goes. I am not sure how much performance the Parallels virtulization chews up, I will have to ask on their forums.
Hey Major,
Just want to say thanks for all your dynamite work on ffmpegx, I just can't wait for the universal version, I'm so excited about it I've done a small wee twice!!
Cheers again.
Major,
This question is not specific to the Intel Macs.
If I am using ffmpegX correctly, it appears that embedding a subtitle (using a ".srt" file)and enlarging the text size must be done while encoding as either XviD or Divx (don't remember which at this moment but I know that you have to be able to alter the subtitle position in order to know that the encoding will succeed).
However, this process can'e be done directly to H264. I need to embedd (and, optionally, enlarge) the subtitle during the first encoding (as Xvid or DivX) and then transcode the resulting file into H264.
At least, this was the way it had to be done up to .9v (and I had to use the .9s mencoder, IIRC).
So I guess there are two questions here:
1. Will I no longer have to swap out the .9v mencoder for the .9s to enbed & enlarge subtitles?
2. Will H264 encoding include the ability to embed and enlarge subtitles?
Thanks. This is not a huge problem.
One more thing: If this process I described will continue to take two steps, might there be some kind of a script that might be possible for me to "fill in the file names and parameters" and then run?
1. The subtitle problem is a bug in mencoder, I will report it to the applicable developers as it starts to be a little long that it is there. The latest sources seem to encode subtitles but don't take font changes into account.
2. mencoder H264 handles subtitles, not x264 H264 (however the same as 1 will apply).
On a side note, it looks like in the Intel version it is possible to restore the audio level feature for mencoder.
With todays announcement of a 17" MBP, I'm just days away from being intel only. Please please release the Intel/UB version of FFmpegX. Or just slip me a beta.
Thanks.
ffmpegX benchmarks
By Case in forum ffmpegX general discussionReplies: 0Last Post: 20th Aug 2011, 12:21 -
clarkdake encoding benchmarks!!!
By deadrats in forum ComputerReplies: 12Last Post: 6th Jan 2010, 18:38 -
lynnfield + tmpg express benchmarks!!!
By deadrats in forum ComputerReplies: 0Last Post: 6th Aug 2009, 21:20 -
first Core i3 benchmarks
By deadrats in forum ComputerReplies: 12Last Post: 2nd Aug 2009, 17:17 -
Core i7 benchmarks!!!!
By deadrats in forum ComputerReplies: 6Last Post: 3rd Nov 2008, 20:33
