I just compiled ffmpeg on Intel with the SSE optimizations. Results are quite good so far, and faster than G5 Dual:
Encoding one minute DVD (NTSC) :
ffmpeg divx 640x272
Rosetta: 2' (14.4 fps)
Universal: 29 sec (60 fps)
ffmpeg xvid 640x272
Rosetta: 3'27" (8.3 fps)
Universal: 37 sec (47 fps)
ffmpeg DVD 720x480
Rosetta: 1'34" (18.4 fps)
Universal: 18 sec (96 fps)
I now go ahead with mplayer/mencoder/x264.
Results 1 to 30 of 89
As i expected.
Confirmes the fps of the universal versions from isquint and handbrake.
True story: My DP1.25GHz G4 developed problems Apple couldn't fix so they swapped it for a DP1.8GHz G5. (Yes, I had AppleCare.) 11 months later the DP1.8 G5's power supply bit the dust and, as Apple was out of power supplies for my unit (they were in the process of building the dual-core units which, apparently, use a different power supply and the factory couldn't break into the production run), they swapped my unit for a DP2.0GHz G5 (one of the last they had in stock before the dual-core announcement).Originally Posted by mrwho
Yes, AppleCare was on both units and they even refunded most of the $$ I spent on it because of the age (11 months) of the DP1.8. Did I buy AppleCare for the DP2.0? You bet your arse!
So I'll wait patiently until the AppleCare runs out or, as I said in my first post on this topic, Apple just gives me a new Intel box when my current unit dies. As Judy Tenova says: "It can happen!"
Compiled mencoder for Intel. The 3-figure barrier has been broken:
100fps for DivX mencoder (a movie can be encoded to DivX in about 20 minutes).
Still working at some optimizations and a problem with ac3 decoding. I hope to release within a week or so.
You have just to work 22 hours hacking the files (and still I have some problems left with ac3 decoding in mplayer).
Major,
Sounds like you need to post some of your hours:donations benchmarks!!! I hope a lot more people would donate when they find out how long it takes to keep this app up to date and running. I know it's a labor of love and all, but when you get v1.0 out, price it to make your efforts worth it.
Thanks for all your work,
Matthew
Can't wait to use ffmpegX in UB 8)
Thank you so much Major for the time you are spendig in making your software better ad better day after day !
Respect!
Cesare G.
ffmpegX registered and much satisfied user 8)
major,
any chance you tell us what did you hack to enable MMX? I checked some of the forums and they all say that there is a bug in the compiler for OSX and it always fails. I had to disable MMX to get it to compile, but as you may know, the results are not that impressive. I get around 40s for one minute video, and that is only on one CPU. Still much better than Rosetta.
Thanks Major. You are a star. Looking forward to trying out the new version.
EDIT:: Don't know if it's any help to you or anyone else here but someone has done a new build of AC3 for intel Macs dated yesterday so it's pretty fresh.
http://n.ethz.ch/student/naegelic/ac3/index.php
Fresh, and still crashy unfortunately, particularly in Front Row (component bungholes Front Row every time I try to play the file). I'm going to mail the author and beg him to do a CoreAudio implementation of a52dec using liba52 from http://liba52.sourceforge.net with a SMAC wrapper. That way all CoreAudio applications will be able to decode AC-3 and the SMAC wrapper will mean that the same CoreAudio component can also be presented to QuickTime for decoding.Originally Posted by ultim8fury
Shepmaster at http://shepmaster.thefridgeowl.com did a CoreAudio wrapper for liba52 but neglected to implement the SMAC wrapper, probably because Shep's approach is just a rip of liba52 into Apple sample code (no disrespect Shep, if you're watching, no point re-inventing the wheel !). I'm no coder, so I'm reduced to begging for this stuff
Heaven only knows why QuickTime doesn't just use CoreAudio instead of Sound Manager now, but I guess that's down to Apple.
Ut.
Kudos to you major. I'm looking forward very much to Universal ffmpegX.Originally Posted by major
Ut.
ffmpegX benchmarks
By Case in forum ffmpegX general discussionReplies: 0Last Post: 20th Aug 2011, 12:21 -
clarkdake encoding benchmarks!!!
By deadrats in forum ComputerReplies: 12Last Post: 6th Jan 2010, 18:38 -
lynnfield + tmpg express benchmarks!!!
By deadrats in forum ComputerReplies: 0Last Post: 6th Aug 2009, 21:20 -
first Core i3 benchmarks
By deadrats in forum ComputerReplies: 12Last Post: 2nd Aug 2009, 17:17 -
Core i7 benchmarks!!!!
By deadrats in forum ComputerReplies: 6Last Post: 3rd Nov 2008, 20:33
