I downloaded this freeware and so far so good in terms of making data backup DVDs. The problem is burning speed. I have a brand new NEC 16x recorder and I'm using brand new 8x Maxell dvds. Thus far, the highest speed I can burn at is 4x--which means it takes two hours to burn one dvd. Is a higher speed not possible with this freeware?
Thanks.
I have a 4x burner, so pretty much everything I burn is at 4x. 4X should take approx 14 minutes 30 seconds for a single layer disc. Even at 1x a single layer disc should take around an hour, not two.
Have you tried the burning software that came with your burner ?Read my blog here.
You filled a 4.7gb dvd in 14 minutes using 4x? Sounds impossible.
Do it every time. 4x should fill a disc in approx 14 minutes 38 seconds (give or take a few seconds). 16x with 16x media should burn in around 6 minutes. 8x should come in around the middle at around 10 minutes.
You also need to remember that a disc is not written to at the top speed. The speed will build up over the burn, possibly starting around 4x and building up as the burn moves across the platter. Full speed (be it burner speed or disc speed) may only be achieved and maintained for a quarter of the burn time or less. The is more evident the faster the burner.Read my blog here.
Originally Posted by guns1inger
If burn speed selected is 4x , then that's what it is burnt at across the disc ... it dosent go faster .
This is due to cas and cav spec's ...
problem with CDburnerXP
By marlo in forum AudioReplies: 2Last Post: 5th Mar 2011, 09:09 -
Question about ripping when internet speed is too slow
By jimdagys in forum Video Streaming DownloadingReplies: 1Last Post: 11th Sep 2009, 02:49 -
dvd authoring speed question
By slaak in forum Authoring (DVD)Replies: 0Last Post: 25th Jan 2009, 13:14 -
magix movie edit pro 12 burning speed problem!
By SKATEBOARDEDITOR in forum Newbie / General discussionsReplies: 6Last Post: 14th Dec 2007, 03:47 -
Dumb question? Burn speed ...
By NukeyDoo in forum Authoring (DVD)Replies: 5Last Post: 27th May 2007, 12:12
