Firstly, I have added some text saying "Play All" on my main menu, then I go to connections, and click "Play All" and it adds a turqiose colored box, then I went back to my menu, and tried to drag "Play All" over the text of the same name to link it as a command, and I got an overlap grid show up in red, what does this mean? have I tried to get my text to "play all" the wrong way? I'm new to Lab so any help appreciated on how to make the play all feature work with text.
Also I am dragging my movies over text on my episodes menu, I have 5 episodes, and 5 lines of text with the features names on, I wish to link the 5 texts with my 5 movies, but it only seems to want to connect one at a time on the connections screen, why wont it connect all 5 movies to the text?
I'm not 100% sure what you are doing from the description, but the way to "Play All" would be as follows:
Create the "Play All" text on your menu. If you have only one video in your project, right click "Play All" and link it to your movie. If you have more than one video, you will have to create a Play List.
To create a Play List, go to the connections menu, and right click somewhere. Then Click Add -> Play List. Double click the newly added Playlist. Then add all of your movies in sequence. Then go back to the "Play All" text on the main menu, right click it, and link it to the Playlist you created.
I use DVD-Lab 1.0, so if you are using a newer version, it may have different features, but this method certainly works
VHS to DVD couple of questions
By buick in forum RestorationReplies: 1Last Post: 27th Nov 2010, 07:14 -
DVD ripping on Mac - Couple of questions
By Anonymous70 in forum MacReplies: 7Last Post: 10th Jan 2009, 05:19 -
a couple of sub questions
By Kanyeeeze in forum SubtitleReplies: 1Last Post: 1st May 2008, 17:03 -
GUI For DVD Author - A Couple of Questions
By deadwing in forum Authoring (DVD)Replies: 8Last Post: 6th Sep 2007, 01:25 -
couple questions
By mainegate in forum ffmpegX general discussionReplies: 2Last Post: 31st Aug 2007, 11:22
