Hi everyone,
This is my first post. If there is an answer to my question already posted,I am sorry,but I have been trying to find one without success.
I started capturing my collection of VHS tapes (Nascar races). Some are going on 11yrs old,and actually the quality is still pretty darn good.
I am going to have quite a few well over 8 gig. The first biggy I captured is 13.7 gig,about 3hr 18min. It is editted down to that size. I was thinking of trying ConvertXtoDVD,but if I understand correctly,it will be downsized to fit a single layer.
Is it possible to knock down the quality just enough to fit a dual layer??
I did use the trial version.It resized the 13.7gig to 4.3gig,I did notice some
falloff in quality.I know VHS quality isn't going to be very good,but I don't want to sacrifice anymore quality than I absolutely have to.
My card is a Hauppauge WinTV PVR 250. I capture in 12.0 Mbit/sec.
My burner is a Plextor PX-716A.
I bought a new VCR (Sony SLV-N750) dedicated for the computer.
I use Verbatim DVD+R DL (already made 3 coasters).
I use VideoReDo Plus for edit.
I have Ulead MovieMaker 4 and Nero Ultra 7.
Greg
any help would be appreciated....dual layers are expensive coasters
ConvertXtoDVD has a dual layer setting. None of the software you are using is recommended for dual layer success however.
Your other options are :
1. Use a standalone encoder (tmpgenc, CCE Basic, Procoder Express) and a bitrate calculator to encode correctly, then use a dual layer capable authoring program,
2. Use a standalone encoder, but resize to half-D1 resolution (acceptable for VHS source) and encode to fit on a single layer disc.Read my blog here.
single layer are a lot cheaper - even using two ..
you can fit about 2-3 hours easy of vhs source on a dvd ..."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
mpeg2 to mpeg2 conversion
By asdfen in forum Video ConversionReplies: 9Last Post: 4th Oct 2009, 14:45 -
Batch conversion of large numbers of DV-AVi to Xvid/Divx
By snehne in forum Video ConversionReplies: 2Last Post: 19th May 2009, 18:04 -
AVI to Mpeg2 conversion
By carlmart in forum Video ConversionReplies: 122Last Post: 13th Mar 2009, 07:04 -
MPEG2 to AVI conversion.
By fl3tty in forum Video ConversionReplies: 5Last Post: 4th Dec 2007, 01:31 -
after conversion to mpeg2 gets interlaced
By forare in forum Video ConversionReplies: 32Last Post: 14th Oct 2007, 00:47
