Hey!! I am looking to upgrade my pc, I would like to add a capture card
I have a problem, my sky box does not have a s-video slot, only an rgb scart slot! This means, I would have to connect to rgb card (if I am correct lol)? Are there many of these cards about, and if so are they expensive?
Or am I best to get a rgb to s-video converter?
Thanks guys!!
Check other threads, google etc. on adaptors? Generally capture hardware has s-vid, RCA, and some sort of antenae/cable connection.
Check here:
http://www.videoguys.com/vidcap.htm
They list several that have component input.
How to capture screen with RGB?
By VHDBBTX in forum Capturing and VCRReplies: 72Last Post: 11th May 2010, 23:39 -
Capture card or Video card w/ capture tool
By joelson in forum Newbie / General discussionsReplies: 1Last Post: 11th May 2009, 11:45 -
YUY2 or RGB for vhs capture?
By RH+ in forum Capturing and VCRReplies: 2Last Post: 3rd Nov 2007, 13:46 -
Capture card with Component (RGB) Input and 16:9 Support
By edt in forum Capturing and VCRReplies: 21Last Post: 27th Jun 2007, 10:58 -
Using Capture/Recoding PCI card - GV-650 Video Capture Card
By Confused Chimp in forum Capturing and VCRReplies: 1Last Post: 6th May 2007, 18:15
