Hi, I'm new on DVD stuff, so here is my question:
Is there a way to convert more .avi files to a single DVD than the typical 4 files (25 minutes each)?
Results 1 to 10 of 10
Yes, if you encode them to mpg at the correct bitrate.
Use a bitrate calculator to find out what that bitrate is. (See TOOLS left)
/Mats -
Thanks for this info, now I have another question, when using tMPGEnc for making NTSC VCD's I set the video arrange method to:
CENTER (custom size)
316 x 216 pixels
this way I could get the hole picture on TV (if not done this way, the edges would not fit on screen).
Now, should I use the same size for a DVD or is it diferent? -
Dvd is 720x480.
Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw? -
OK, something went wrong, I used the calculator in java with the following ajustments:
Video Lenght : 3 hrs 20 min
DVD's : 1 x 4.37 GB (DVD5)
Custom size : 4480
bps : 1 kbps = 1024 bits
Audio Bitrate : 128 kbps
Custom audio : 128 kbps x 1 track
ISO : 100 MB/DVD
Calculated Bitrate : 2799 kbps
DVD Max Bitrate : 9442 kbps
With this result, I converted one file of 250 MB (25 min) in TMPGEnc. and got a .mpg file of about 435 MB. But when adding this file to Nero Vision Express it reads a whopping 2.5 GB.
Maybe I did the calculation wrong (I put the video lenght as to how long 8 movie files would last). Or maybe because I used TMPGEnc (trial version ) thats expired and converted to MPEG 1 and not MPEG 2.
Any ideas... anyone? -
Yes, don't use nero for authoring your DVD, or turn off the "make standard compliant" option. Nero is trying to re-encode your video. Use a real authoring program instead..Originally Posted by guy with a stick"Art is making something out of nothing and selling it." - Frank Zappa
Or 352x480, or 352x240Originally Posted by yoda313
/Mats -
Thanks for the extras guys.
And @jimmy - the location for the original poster was mexico so I knew it had to be ntsc :P :P
And actually mats forgot the 704x480 as an extra resolution option.
But back to the original poster 9 times out of ten 720x480 should be what you choose.Donatello - The Shredder? Michelangelo - Maybe all that hardware is for making coleslaw?
need help regarding dvd clips
By lullaby49 in forum EditingReplies: 1Last Post: 13th Mar 2011, 04:28 -
Export HDV clips to SD clips from Premiere Pro CS3
By foochuck in forum EditingReplies: 10Last Post: 8th Jun 2010, 18:03 -
Clips for DVD's?
By pianoman1976 in forum MacReplies: 2Last Post: 30th Jan 2009, 20:52 -
What is the best way to gather clips from various DVD's?
By JediPM in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2008, 11:30 -
How to make clips from a DVD?
By Soccerman77 in forum EditingReplies: 2Last Post: 12th Oct 2007, 06:44
