I am capturing with a Dazzle DVC II. I then edit it to cut out commercials. From this site I was told to then run the MPG thru tmpgenc. that takes about 2 hrs for 45 minutes of mpg. I then burn a VCD with NTI. I recently skipped the middle step and just burn the VCD from the edited file. Am i doing something wrong in this? I see no difference in the quality just a large time savings? Is the tmpgenc step really just overkill since its already in MPG form and not AVI??
Would I see better VCD results with Nero over NTI?
I don't know what NTI is
But if the Dazzle is capturing MPEG1 or MPEG2 stream and the quaility is ok, just go ahead and burn it. TMPGenc is to encode MPEG1/2 files, no need to re-encode (will only lower quaility).
yeah, just use ur captured MPEG's
U have a hardware assisted encoder, u should have good quality.
Software Problem NTI Media maker no menus
By music_freak in forum Authoring (DVD)Replies: 3Last Post: 19th May 2009, 17:32 -
Tmpgenc dvd mpeg is not smart rendered by Nero
By perfection in forum Authoring (DVD)Replies: 3Last Post: 17th Dec 2008, 15:00 -
[Help] Problems creating VCDs.
By scott274 in forum Newbie / General discussionsReplies: 77Last Post: 15th Jul 2008, 02:43 -
I want to play VCDs on my laptop
By Michel-lyn in forum Software PlayingReplies: 2Last Post: 22nd Dec 2007, 10:38 -
Sound Problem Burning DVD with Nero 7 and TMPGEnc
By brandonc in forum Authoring (DVD)Replies: 4Last Post: 28th Nov 2007, 19:40
