  1. Hello
    I recently came in control of a PAL dvd, however live in the United stats,
    What program can I use to convert this PAL disk to a NTSC and burn it onto a DVD-R?
    Or is this eveb possible?
  2. those links dont seem to tell me enough
    Which guide shows me the way using the BEST program (quality not speed) to do it, keeping themovie thebest it can without jumpy scenes etc?
  3. Member hech54's Avatar
    Jul 2001
    Yank in Europe
    Your question is asked here at least 3 times per day. To put is nicely....converting is not easy via a computer. It is much easier to go out and buy an inexpensive DVD player that can convert from PAL to NTSC on the fly.
  4. Get a lite-on DVD recorder. They play back PAL great! No easy way to convert them.
  5. ok cool, thats defintly an option for me too
    as I am looking for a new dvd player
    I put up a new threat in the dvd player section,
    https://forum.videohelp.com/viewtopic.php?t=294820
    anymore help would be awesome
