I have a few hundred music clips captured from tv that are in a mpg format and around 200 mb each.
I've made dvds of the clips but also wanted to keep them on the pc to watch but need them to be at a reduced size. I used nero to convert one to xvid and got it doen form 200 mb to around 22 mb. I know there is a drop in quality but as a trade off between drop in quality and size i'm perfectly happy with it - looks fine on the pc.
Thing is i can't see anyway to batch converet in nero, it looks like i have to do each file at a time. This will take ages with nero so i had a lok elsewhere. One that i looked at was alltoavi, which looked perfect yet when i convert a file to xvid (picking high quality) it's noticeably worse quality than nero.
Can anybody reccomend a good convertor that has a batch mode ? I was surprised at alltoavi as it was highly rated. It doesn't have to be xvid or divx i would probably be happy with wmv if i got reasonable quality at a small size.
In the actual allto avi program there aren't many settings for the xvid codec - perhaps i should change settings in the actual xvid codec before running alltoavi.
These clips don't have to be of the highest quality as i am happy with the dvds i've made just wanted some small clips to keep on the pc.
Anyway thanks for any help
Is there a good command line tool that will do the same? Need to go from MGP to avi (Divx or Xvid)
Convert Divx to Xvid batch
By nick7461 in forum Video ConversionReplies: 8Last Post: 2nd Oct 2021, 12:37 -
Best way to batch convert xvid/avi files to mkv/x264 files?
By gaikokujinkyofusho in forum Video ConversionReplies: 1Last Post: 13th Jan 2012, 07:31 -
Convert WMV to AVI / DivX / Xvid
By p_uriel in forum Video ConversionReplies: 5Last Post: 14th Feb 2010, 22:40 -
Batch convert ISO to AVI/Divx/MPEG
By extrememc in forum Newbie / General discussionsReplies: 1Last Post: 11th Jan 2010, 19:13 -
Best Batch convert tool for WMV to DIVX
By hsantos in forum Video ConversionReplies: 3Last Post: 28th May 2007, 09:48
