I need a vcr that records both VHS on VHS tape and SVHS on SVHS tape. The recorded tapes must then be able to be played back the same way: VHS tape in a VHS deck and a SVHS tape in a SVHS deck. I am finding that the JVC vcr's record SVHS on a vhs tape but it cannot be played in a vhs vcr, however I hear the SR V101US model may accomplish what I need. ??? Thank you.
It's not true S-VHS recording unless it's done on an S-VHS tape. There are standard VCRs that will play S-VHS tapes, but they do it in standard resolution. Any S-VHS VCR will record VHS and S-VHS and will play both.
My JVC HR-S3800U records VHS on VHS tapes which can be played back on any VHS or S-VHS tape player. It also records S-VHS on S-VHS tapes which can be played back on any S-VHS tape player.
What may be confusing is that JVC will also record a hybrid called S-VHS ET which is S-VHS recorded on VHS tapes. These tapes will likely only be playable on JVC S-VHS VCRs.
As long as you avoid S-VHS ET then JVC S-VHS VCRs do exactly what you want.
-drjThey that give up essential liberty to obtain a little temporary safety deserve neither liberty or safety.
--Benjamin Franklin -
Turn off ET mode. Read the manual.
Why don't you check this thread out before making your desicion.
https://forum.videohelp.com/viewtopic.php?p=1474013#1474013
The local shop has not looked at mine yet.
Other than the color banding, both JVC's do a nice job; even the 2901.
I really did not see a big difference in picture quality on most of the tapes when comparing the 2901 and the 7600 even with changing the settings. I guess I will see a substantial difference when I get a really crappy tape to convert. What a bite!
Capturing SVHS using a standard VHS VCR - Is it possible?
By DJ Kris in forum Capturing and VCRReplies: 15Last Post: 4th Jul 2020, 13:00 -
Need Help Urgently Capturing from SVHS VCR
By Hairykiore in forum Video Streaming DownloadingReplies: 9Last Post: 4th Aug 2011, 20:26 -
I need an SVHS VCR
By yummyme in forum Newbie / General discussionsReplies: 16Last Post: 17th Nov 2010, 04:00 -
JVC HR-S3900U svhs vcr
By DVWannaB in forum RestorationReplies: 1Last Post: 8th Dec 2009, 13:20 -
New Capture VCR for old VHS/SVHS tapes
By mark23 in forum Capturing and VCRReplies: 3Last Post: 22nd Feb 2008, 10:44
