HEy i got a Dansai DVD852S but i can't find a suport webpage ?! so anyone that got some detailed info about this excellent DVD Player `?! also any hacks or firmware if it's upgradeable.. donno about that.. well any info u got is apriciated.. thx
I just bought one of these myself. Really good spec aren't they. I found out about them on the net first cos I hadn't heard of them. They get good reviews from posts I've read. You can get info in the forums here:
http://www.dvdreviewer.co.uk
and the hack is here, you can also turn macrovision off there too:
http://www.dvd.reviewer.co.uk/info/multiregion/full/Dansai852.asp
Mark. -
Great Machine !!!!! - Plays the following : VCD / SVCD / DVD / XVCD / SXVCD / DVDR / DVDRW / CDR / CDRW / MP3 - The machine also has this function called 'DIGEST' which allows you to look through the contents of a CD/CDR and pick out any files you'd like to try and play or view.... works with Jpeg's / Wavs / .mpgs.....
VIDEO_TS info
By ecos in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2010, 19:55 -
Mediainfo File Info tool "Format Profile" wrong info problem
By dabas in forum Newbie / General discussionsReplies: 2Last Post: 9th Mar 2010, 06:07 -
Codec info
By stigslim in forum Software PlayingReplies: 3Last Post: 11th Feb 2009, 04:33 -
any info on LG DN898
By insyder in forum DVD & Blu-ray PlayersReplies: 0Last Post: 8th Jan 2009, 01:28 -
Need some general info...
By bjgdal in forum Media Center PC / MediaCentersReplies: 1Last Post: 2nd Jan 2009, 22:29
