Hi, I burned an avi file to dvd and when playing it on my dvd player, the image is squashed horizontally to fit the standard (pan and scan) tv screen I'm using (I need to get a wide screen tv!). The original movie is in letterbox format and I used Showbiz 2.0 to burn the disc (though I also have Nero). I tried adjusting the display settings on my dvd player, but this didn't work.
How can I re-rip this so that it displays in letterbox on my tv? Or is there a setting somewhere I can tweak without needing to re-rip?
Thanks.
You could try changing the AR flags in the IFO using IFOEdit. This might be enough for yur player. It sounds like Showbiz doesn't support 16:9 encoding, in which case you need to use an encoder that does. Tmpgenc, CCE Basic, Procoder Express all support 16:9 encoding. If you want a simple solution, ConvertXtoDVD also supports it.
Read my blog here.
How to Maintain Correct Aspect Ratio in PotPlayer with Full Screen
By drstew12 in forum Software PlayingReplies: 1Last Post: 20th Dec 2011, 20:25 -
Converting .mov to Flash - Can't Maintain Aspect Ratio
By cchrisj in forum Newbie / General discussionsReplies: 2Last Post: 9th Sep 2010, 10:53 -
How To Maintain Proper Aspect Ratio?
By Bonie81 in forum Authoring (DVD)Replies: 4Last Post: 2nd Sep 2010, 20:23 -
How can I maintain the Aspect Ratio in MeGUI?
By Newtype in forum Video ConversionReplies: 2Last Post: 1st Feb 2010, 10:06 -
AVI to DVD with different aspect ratio
By germ in forum ffmpegX general discussionReplies: 16Last Post: 7th Apr 2008, 23:50
